Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 12-17-2023, 06:50 PM
lbos021167 lbos021167 is offline
Thermostat location
Looking for thermostat on 2018 Ford escape SE 1.5l ecoboost
Old 12-25-2023, 05:06 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Thermostat location
It is on the left front of the cylinder block as observed from in front of the vehicle. If you have a leak in the area, it might actually be the water pump leaking and not the thermostat housing. The water pump on these engines doubles as the idler for the timing belt and as such, you will need to use a timing tool set to properly do this job. It would be a good idea to replace the timing belt as you are there anyway. The crank pulley on these is keyless meaning the crank and cam both have to be locked in a specific location in order to remove the belt. There is a toolkit on amazon for this which is around $50.
Do NOT attempt this unless you are willing to forfeit your engine. You MUST absolutely know what you are doing.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Tags
thermostat
