| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Run cars on propane?
I found out that it's possible to run cars on propane. I have seen RVs that have "No Propane" signs. Why?
Re: Run cars on propane?
If your day is gone, and you wanna run on propane,
Don't forget this fact - you can't get back, propane!
Longacre Racing... The BEST Tire Gauges 1 AU from the Sun! |
Great, now that song is stuck in my head. There are definitely worse things in life though....
-Rod |
Why do RVs have "No Propane" signs?
Are they maybe rental RVs and they don't want the people renting them to inadvertently put propane in them? Or were you maybe seeing the fill port for the generators, and on the RVs you noticed these signs on, maybe they are gasoline/diesel generators rather than propane? Or maybe this whole "low emissions" push has cause some folks to want RVs that don't rely on propane for the RV furnace, water heater, and multi-mode refrigerators so they are advertising that the RV does not require propane to power those devices. Kind of like the large "Hybrid" stickers that GM used to stick on the lower bodies of their hybrid SUVs.
Without having a bit more detail on where the signs were and which RVs you saw these on, it will be pretty challenging to provide you with a definitive answer. -Rod |
It's a sign for first responders in case of an accident or fire. If there is propane there is the possibility of explosions and they might just watch it burn.
| The Following User Says Thank You to Stealthee For This Useful Post: | ||
shorod (12-24-2023)
