Old 11-01-2023, 11:59 AM
Aweeks89 Aweeks89 is offline
Secondly fuel filter
I have a 1997 jeep cherokee se 2 door, I know the fuel filter is in the tank. My question is , would it be possible to add a secondary inline fuel filter?
Old 11-01-2023, 01:17 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Secondly fuel filter
Yes, absolutely if done right.
Curious what issue you're having that you'd want or need to do that?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 11-01-2023, 03:57 PM
Once it gets lower then half a tank it sputters and has a hard time getting speed ( like it's not getting fuel) one we fill it up, it's back to normal.
Also thank you!
Old 11-01-2023, 03:59 PM
Also have to hold the gas to keep it going then after a few it's fine.
Old 11-01-2023, 04:22 PM
There is a thread on here I think from years ago with a similar problem.
I will see if I can find it, but do a search of you might be able to find it yourself…
If I remember correctly, the solution was to -unfortunately- drop the gas tank and replace the fuel pump and filter in the tank. It's kind of a big job, but from how you describe it, the problem is not with enough filtration in the fuel system but that it's either a weak pump, clogged filter in the tank, or both.
Old 11-01-2023, 04:27 PM
Okay thank you, I appreciate that and that's what I was afraid of. It's definitely not a fun job . I will definitely look for it.
Old 12-28-2024, 02:03 AM
wenliangwen wenliangwen is offline
https://www.hydraulicthrowoutbearing.com/Jeep/
Hydraulic throwout bearing
