Old 10-04-2023, 07:07 PM
RidingOnRailz's Avatar
RidingOnRailz RidingOnRailz is offline
Cool 2005 Toyota Corolla - Loud Rattling Noise Passenger Rear Corner
Title says it all. Car has 185,000 miles on it, no known rear suspension work.
I test drove the car around the block before night-boxing it at our nearby shop.
Over manhole covers and moderate bumps the right rear wheel area sounded like a metal trash can falling down a metal New York fire escape.
Car accels and handles fine, and when I got out and pressed hard down on the left and right rear corners of the trunk, there was no excessive rebound. Just a noticeable squeak from the rear end.
A crawl on my back underneath the rear end revealed goose eggs.
What gives?
Longacre Racing...
The BEST Tire Gauges 1 AU from the Sun!
Old 10-05-2023, 05:19 AM
Re: 2005 Toyota Corolla - Loud Rattling Noise Passenger Rear Corner
Sighhh....
I guess some bot from Whatzitstan will chime in.
Longacre Racing...
Old 10-05-2023, 09:27 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Does the car have a rear anti-sway bar? The description of the sound seems pretty consistent with a bad anti-sway bar end link. Another thing to try would be to remove the hub caps and see if the noise disappears. It's not uncommon for hub caps to trap rocks or other debris, or to break and rattle.
-Rod
Old 10-06-2023, 07:28 PM
Cool Re: 2005 Toyota Corolla - Loud Rattling Noise Passenger Rear Corner
-Rod
Thanks to those who offered up suggestions.
It turned out to be a strut that broke at the top. Local independent made note of it's position, wrestled the sum'bich out of there, and installed a replacement.
I don't know what caused it to break/ separate in the first place. My wife drives reasonably fast but prudently, staying right most of the time, and avoiding road hazards(sub-grade manhole covers, pot holes, what-not).
This car has 184,000 miles on it presently, and these are likely the original struts in back. So it sounds like it's about to turn on to the Road of Diminishing Returns...
Longacre Racing...
Old 10-06-2023, 08:56 PM
shorod's Avatar
SHO No Mo
Wow, that could have been a nasty surprise for her if she kept driving it and hit a large pothole or something that allowed the spring to escape the strut!
Thank you for following up with what you found the issue to be.
-Rod
Tags
corolla , rattle , rear , toyota
