Old 10-01-2023, 08:50 PM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
1970 Superbird
Resin kit by Starter in 1/43rd scale.
Not a bad casting all things considered. After cleaning up the flash I started scribing in the panel lines.
I'm not sure why there was a panel line molded into the hood just ahead of the hood pins, but I filled it. (Still needs a little more attention.)
The wing uprights were warped, but some creative clamping and heat did a decent job of correcting that issue. I added steel pins for strength and drilled the fenders with oversized holes to limit the friction. I expect the wing to be very fragile.
Old 10-02-2023, 01:37 PM
Re: 1970 Superbird
The raised edges at the base of the vinyl top on the B pillar were molded unevenly, and not prototypically. I replaced them with some 0.010 x 0.020 strips of styrene.
Old 10-03-2023, 10:37 AM
Re: 1970 Superbird
The wheel centers are white metal that is chrome plated. I shot them with clear flat and then painted the centers of them metallic gray. The outers are plated brass and they shined up well after polishing.
Old 10-03-2023, 05:46 PM
Re: 1970 Superbird
The rear wing is a thin strip of brass cemented to the resin fins. It is very delicate.
Old 10-04-2023, 09:31 AM
Re: 1970 Superbird
The kit provides decals for the Goodyear lettering, but they are the wrong size and style. I made new era-correct ones and added the Polyglas lettering too.
Old 10-04-2023, 12:48 PM
Re: 1970 Superbird
I drilled out the stub for the antenna and filled the hole for the passenger side mirror.
Old 10-05-2023, 09:28 AM
Re: 1970 Superbird
I went with Tamiya Pure White even though the correct Alpine White color is not as clean. Sometimes smaller scales need a little boost in contrast.
Old 10-06-2023, 09:40 AM
Re: 1970 Superbird
The seal on the nose is very prominent on these cars, and making it the only black panel line looked wrong. So I blacked out the hood, cowl, trunk and door lines too.
Old 10-06-2023, 12:18 PM
Re: 1970 Superbird
Then I went back and airbrushed white over all the panel lines except the nose seal to balance the contrast.
Old 10-06-2023, 06:04 PM
Re: 1970 Superbird
I noticed the magenta color was not printed in the Road Runner bird decals so I printed a new set from the art I designed for the Revell/Monogram Superbird. I also made the other badging and used the same license plate.
The decals are on the body and the trim & details are painted. After they dry for a while I'll add the vinyl top texture and color. I'll apply the black panels on the nose after the top is done. I also removed the Pentastar from the driver's side.
Old 10-07-2023, 09:07 AM
Re: 1970 Superbird
Nothing too special about the interior. I added woodgrain to the console.
Old 10-07-2023, 09:55 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Re: 1970 Superbird
Very clean work so far. I like painting over the panel lines to lower their contrast, but the trick of painting the edge of the roof at the chrome trim before doing the texture is very clever, and I'll have to remember that. Great work, as always.
The Following User Says Thank You to willimo For This Useful Post:
Scale-Master (10-08-2023)
Old 10-08-2023, 11:23 AM
Re: 1970 Superbird
I have been making my vinyl tops by spraying on the texture since the early 80's; even done some with tape. But this time I did it by freehand brushing with acrylic black paint. Very easy and no masking needed.
Old 10-08-2023, 03:16 PM
Re: 1970 Superbird
One of the first things I did when I started this kit was to deal with the windows. They were yellowed quite a bit, (like most of these kits are now). After I cut the individual windows out I put them in the sun for a couple weeks to try to get them a little clearer.
I planned to not use the door windows so I did not put them in the sun so I could compare later. The contrast between the yellow tone on them to the others that have been sun-bleached is quite noticeable.
Old 10-08-2023, 05:02 PM
Re: 1970 Superbird
I thought I'd use the kit decals for the black panels on the nose because they were printed in flat black. Unfortunately one of them broke into a few pieces when I went to apply them. So I had to make new ones.
The Following User Says Thank You to Scale-Master For This Useful Post:
mrgixxer (10-14-2023)
