Old 09-07-2023, 07:13 PM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
Lotus 56B Turbine Indy
While I was doing research on the 1/43rd scale Lotus 56 I pulled this from my stash. I decided to build it too. This is the old MPC kit in 1/25th scale. It will essentially be a curbside so that the body will fit better than having the top sections removable, but I'll build all the internal stuff too.
I built up the insides, engine and suspension and was able to make it a standalone subassembly so the seam on the nose could be filled. Most of the parts are chrome plated so they were stripped first.
Old 09-14-2023, 04:55 PM
Re: Lotus 56B Turbine Indy
The wheels are on the simple side, but a little paint does wonders. The tires on the other hand are not correct but I'll use them anyway.
Old 09-15-2023, 12:25 PM
Undercoat for the fluorescent red. Yes, it is pink.
Old 09-15-2023, 02:32 PM
The red is Tamiya TS-36. This is about an hour after I painted it. It will now sit in the drying closet for a while.
Old 09-17-2023, 05:47 PM
This little tractor comes in the kit too. I assembled and painted the main components first starting with the wheels/tires.
The engine…
I added some detail to the muffler.
And the frame with the battery and transmission installed. I added a little wiring to the engine and battery.
Old 09-18-2023, 02:56 PM
I went with Tamiya Italian Red for the body parts. Warbird Decals black & brown woodgrain was used for the push board.
Old 09-18-2023, 07:43 PM
This is as much as I can build up of the chassis & suspension until it is installed into the lower section of the body.
Old 09-18-2023, 07:46 PM
The tractor is finished.
I machined new center nuts for the wheels and made some decals. I dirtied up the engine a little more too.
Old 09-23-2023, 05:10 PM
The decals aren't too bad, especially considering when they were printed and the process used, but all of the STP logos lacked the white outlines.
So I made new ones.
Old 09-28-2023, 03:37 PM
I cleared it a few days ago. No unexpected negative issues have manifested.
Old 09-29-2023, 01:41 PM
The last photos of the innards before it is sealed up.
