Old 08-13-2023, 10:54 PM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
Lotus 56B Turbine F1
SMTS kit from the 80's. Nicely cast white metal. The body needed a little clean-up from worn molds, but overall it is quite nice.
Old 08-25-2023, 12:48 PM
Re: Lotus 56B Turbine
The decals are (like many kits from this era) yellowed. Making replacements is not a problem, but if the artwork isn't bad, even if it is a bit dated, I like to try to build these kits using what comes in the box.
These have been taped to the inside of a window in my shop that gets direct sunlight for most of each day to sun-bleach them for two weeks.
Both the clear and the white benefited from this.
I'll put them back on the window until they are needed just to get maximum results, but this is possibly as bleached as they will get.
The Following User Says Thank You to Scale-Master For This Useful Post:
mrgixxer (08-26-2023)
Old 08-31-2023, 08:51 PM
All eight tire decals went on just fine, so clearly there are no ill effects of sun-bleaching there.
The gauge decals went on fine too…
Old 09-06-2023, 02:23 PM
The suspension on these kits is actually engineered pretty well, but due to the nature of the white metal some parts had to be bent into shape. This one took a good amount of fiddling to get the wheelbase equal on both sides with no binding between the body chassis and suspension.
Old 09-07-2023, 02:21 PM
The body is painted and ready for decals… Tamiya lacquers.
Old 09-13-2023, 11:32 AM
The decals were very workable, after applying the ones for the tires and dash I had no worries about them cracking or being overly fragile due to the sun-bleaching. They responded well to solvent and that was needed to get the Gold Leaf logos to conform to the bulge of the fuel tanks and the gold around the nose.
I mixed a gold for the front wings to go with the decal from Tamiya Titanium Gold and Clear Yellow.
Old 09-21-2023, 10:18 PM
Once the clear has cured I'll do some detail painting and start final assembly.
Minor setback when I shot the clear last week; a gnat landed in a prominent area and flopped around before I could pluck it out and it stained the clear. So once the clear dried I had to spot paint/blend some red in to hide the stain and re-clear that area and blend it as well.
