Go Back   Automotive Forums Car Chat > Dodge > Ram Van
Old 07-14-2023, 08:24 PM
twistedpixel twistedpixel is offline
1999 Ram 1500 van. No air from face level vents
just picked up my 1500 van, planning on converting to a camper. I'm likely to have several questions but I'm starting with the most important to me.
Driving it home 534 miles from OR to CA in 90 degree heat was not comfortable because I don't get any air out of the face level vents.
Air from foot vents - perfect
Air to windscreen - perfect
Air to face vents? nothing.
I suspect it's hose related and not diverter valve since it moves from feet to windscreen without issue. Can anyone tell me where the hoses meet? eg left side of dashboard, right, center...before I start looking in the wrong place. Hoping to simply find a disconnected hose
Old 07-15-2023, 04:01 AM
brcidd's Avatar
brcidd brcidd is offline
Re: 1999 Ram 1500 van. No air from face level vents
I'd look on the engine intake manifold for the plastic or rubber vacuum line that drives the mode door. Chances are really good it is melted, broke, brittle, and sucking air. Find and fix the leaky bad vacuum hose- also there is probably a vacuum reservoir/canister to check the hose connections. The easiest way to find the hose is to start at the vacuum reservoir and trace lines to the intake manifold and to where it goes into the dash conduit in the other direction. Since it is diverting air to the floor- then it must be a partial leak-- 100% leak (unplugged, etc) will put all air to the defroster- so that it defaults to defrost so that there can never be a safety hazard due to foggy windshield in case of vacuum leaks.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 07-15-2023, 09:00 AM
alloro alloro is offline
The vacuum canister is under the passenger headlight and the vacuum hose from it runs to the middle passenger side of the intake manifold. At the manifold there is also a one-way check valve. You should also check that to make sure air only passes through it one way. If you remove it, note the direction so as to reinstall it the correct way.
