Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 07-05-2023, 08:48 PM
crcook84 crcook84 is offline
1998 Dodge Dakota won't start in PARK, starts in REVERSE
So, I was tinkering around with a 1998 Dodge Dakota I recently got for cheap and am in the process or restoring. I had it up on jacks so that I could attempt to pass the monitors because the previous owner allowed the registration to expire. Well, as I was shifting back into PARK, I'm not sure I had the brake pedal completely depressed. I turned it off and attempted to turn it back on and it wouldn't start. I left it for a week because I had other things I was doing. The next weekend I had off, I decided to see if it was the starter, the ignition system, or something else entirely. On an impulse, I decided to try shifting it into REVERSE to see if that would start the car. It did, Once the car was started, I tried the various shift positions to see how they would react. PARK keeps the car from moving. REVERSE acts like neutral in that the car moves freely. NEUTRAL and DRIVE both put the car into drive.
I tried replacing the neutral safety switch because I was getting a P1899 error code. It didn't fix the shift situation. However, the code stopped showing. My next thought is that I need to replace something inside the transmission pan area. I did find something on YouTube about replacing the governor pressure solenoid. However, I'm not sure if it's that solenoid or another one that needs replacing.
Old 07-05-2023, 10:11 PM
Re: 1998 Dodge Dakota won't start in PARK, starts in REVERSE
Update: It will start in PARK if the car has been sitting a while. However, if I start it in PARK, turn it off, and try to start it again, it won't start unless it's in REVERSE.
