Go Back   Automotive Forums Car Chat > Cars in General
Old 07-03-2023, 09:44 AM
Spookums Spookums is offline
2005 Mazda 3 Randomly speeds up / down
When going steady speed, my 2005 Mazda 3 Manual slows down / speeds up a tiny amount every few seconds / minute. No RPM changes when it happens.
Manual transmission
Old 07-03-2023, 11:35 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 2005 Mazda 3 Randomly speeds up / down
Welcome to the forum. Please quantify the amount the vehicle speeds up/slows down. If it's enough to be noticeable, but you don't notice a change in the engine speed, that could pretty much only mean the clutch is slipping. But realistically even then I would expect you'd notice a change in the engine speed as the engine becomes loaded or unloaded.
When stopped and in neutral or with the clutch pedal fully depressed does the engine idle at a constant speed or does it speed up and slow down at about the same rate?
-Rod
Old 07-03-2023, 12:12 PM
-Rod
It’s very slight, but the rpm’s don’t change. Last time clutch went bad RPMs would go up fast without acceleration. No issues when idle.
Old 07-04-2023, 01:37 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Cruise on or off? What gear? Flat terrain or rolling?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 07-04-2023, 08:13 AM
shorod's Avatar
SHO No Mo
So is "very slight" 1 mph, 2mph, less than 1 mph?
When a clutch is bad and slipping considerably, yes, the RPMs will raise quickly without the vehicle speed changing appreciably. But if the clutch disc is in the early stages of "worn" or is contaminated with engine or gear oil, or possibly even just glazed, the symptoms may be less obvious.
I suppose one other thing you could try to rule out the rest of the driveline would be to shift to neutral while at highway speeds on a level or even slight downhill, unpopulated highway and see if the vehicle speed seems to pulse in a similar fashion. If not, and the engine speed is truly also not changing, that leaves the only option as the interface between the engine and the driveline (ie: clutch).
-Rod
Old 07-04-2023, 08:46 AM
Cruise off. Every gear I assume, but not sure. Flat terrain
Old 07-15-2023, 08:06 AM
Since rpm do not change, cruise off I would guess that either small variation and elevation or your right foot are to blame… Try it with cruise control on and in different gears and report back.
