Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 07-01-2023, 02:11 PM
Skawry Skawry is offline
2011 Grand Cherokee won’t start
So the car won’t start by itself but will start on a jump, battery is good, lights are bright. When I took it for a spin after jumping it, it ran perfectly as before(it’s getting enough fuel I think). When I turn the key it does a turn then stops. Any ideas? It’s a 2011 overland with the hemi.
Old 07-01-2023, 02:35 PM
aleekat aleekat is online now
Re: 2011 Grand Cherokee won’t start
Did you put a voltmeter on the battery when cranking?
Post back, that's what makes Forums Work.
Old 07-01-2023, 03:38 PM
I did not yet, your saying I should check to make sure the battery is pushing power when I try to crank it?
Old 07-01-2023, 04:20 PM
Yes. Without a voltage check you're just guessing. Or take the battery to any parts store for a load test. How old is the battery?
Old 07-02-2023, 07:24 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Yup, load test the battery. Sounds like it's on its way out.
While you're at the parts store, have them check alternator output as well.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 07-06-2023, 01:25 PM
So I had the battery tested, results came back good. 12 volts. I got a multimeter tested it and got 12 volt, then while I try to crank it the voltage drop to about 10.5, is that normal? Also a more detailed description on what the car is doing, basically when I turn the key I hear the engine crank once and then it quits, it’s not a consistent turn, just once and off(note it’s a push to start)
Old 07-06-2023, 01:48 PM
Did they do an actual load test or just check battery voltage? 12v static is low. I would check all cables. Clean and tight. At the starter also. Measure voltage at the starter. You may have a voltage drop at the starter.
The Following User Says Thank You to aleekat For This Useful Post:
Skawry (07-06-2023)
Old 07-06-2023, 01:59 PM
How do you check starter voltage?
Old 07-06-2023, 03:13 PM
Numerous YouTube videos. You never said how old is the battery?
Old 07-07-2023, 05:39 PM
The battery is new, I did the starter circuit test and got around 3 volt’s resistance on all three power, s terminal, and ground. What’s the next step?
Old 07-07-2023, 05:55 PM
Double check all cable connections. Clean and tight. Check all grounds.
http://www.aa1car.com/library/voltage_drop_testing.htm
Old 07-07-2023, 06:18 PM
I check the the battery connections didn’t see any signs of corrosion, went over everything with a wire brush just to be sure, connections are tight. I checked the starter by touching one end of my multimeter to the ,power circuit and positive battery post, s terminal to positive, ground to negative, all on dcv.
Old 07-07-2023, 07:05 PM
Confusing. 3v resistance? Do you have 12v getting to the starter via battery positive cable?
Skawry (07-07-2023)
Old 07-07-2023, 08:27 PM
Smile Re: 2011 Grand Cherokee won’t start
I’ve decided to go to my mechanic and have him take a look at it, I’ll make sure to come back to this thread and tell you what he finds. That being said I really appreciate your help I’ve definitely learned a few things
Old 07-07-2023, 08:44 PM
Ok. I wondering if your starter is bad?
