Go Back   Automotive Forums Car Chat > Honda > General Discussion
Old 05-25-2023, 11:30 AM
rp2121 rp2121 is offline
HONDA PILOT 2005 ALternator?
My 2005 Pilot is clicking when attempting to start it. The battery is new, the alternator was replaced 4 years ago and the starter was replaced 3 years ago. The car will not take a jump.
Any thoughts??
Thanks so much!
Old 05-25-2023, 03:55 PM
aleekat aleekat is offline
Re: HONDA PILOT 2005 ALternator?
You need to put a voltmeter on you battery. Static then cranking voltage reading. And if you get it running, running reading. Sounds like your alternator not charging and killed your battery. A really depleted battery you won't be able to jump.
Post back, that's what makes Forums Work.
Old 05-25-2023, 05:03 PM
Thanks for the response.
If i put a new battery in and it still doesn't take a jump it wouldn't be the alternator correct? A bad alternator should at least take a jump even if it dies quickly?
Old 05-25-2023, 05:48 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Check your connections. Make sure you have good grounds.
