Old 05-18-2023, 08:58 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
1993 Porsche 911 Carrera 993 Supercup
1/43rd scale resin kit by Starter.
I typically bring something to tinker on or clean up while I'm relaxing at the GSL. This is what I picked for the last one, but I didn't get much done on it; maybe an hour of pre-paint prep in the hotel room.
The body casting was pretty clean with only a few medium pinholes to fill, but the window trim was a little on the soft side. A couple light coats of white primer and it looks OK.
First coat of the body color, and the instructions…
Old 05-19-2023, 10:26 AM
Re: 1993 Porsche 911 Carrera 993 Supercup
After the first base coat of yellow I pre-shaded the panel lines with black.
The second and final coat of TS-47 Chrome Yellow.
Old 05-20-2023, 05:31 AM
malscar's Avatar
malscar malscar is offline
don't see much in 1/43, the casting looks to have held up very well compared to today's ones.
Old 05-20-2023, 09:40 AM
Yes, it is a good casting, but the decals have not held up too.
I probably should have started with a smaller decal… The first one cracked into many pieces and fell apart when I tried to apply it.
I mixed a bright red with Tamiya acrylics and hand painted that one in.
I clear coated the rest of the decals, but they are still very fragile. The black is two decals but needs a good amount of touching up still.
I figured I'd start painting the window trim too...
Old 05-22-2023, 10:41 AM
The other single color decals are just as brittle so I had to paint them in too.
Old 05-27-2023, 02:02 AM
malscar's Avatar
the decals with a lot of old Starter, Provence Moulage and even Racing 43 stuff all have that problem, they also can shatter in the water.
Old 05-27-2023, 12:27 PM
Ain't that the truth!
One of the tire decals fell apart and since I didn't have an extra I had to make four new ones myself.
The rims are a combination of metal outers with resin centers and PE rings.
Old 05-30-2023, 03:35 PM
The interior is done. There was no shifter in the kit; sometimes there is, other times there isn't. I added the two roll bar supports too. They are shown on the instructions but are not included. I guess it's still "out of the box"… The gauge decals are a nice inclusion.
Old 06-02-2023, 12:02 PM
I was able to get more of the decals applied, but even with two coats of clear they are breaking apart so it's like applying a jigsaw puzzle for each one.
Old 06-03-2023, 04:47 AM
Deathtrap Deathtrap is offline
I've always liked this livery. The bright and contrasting colours are a joy to watch. A shame of those decals, I guess they are quite old.
Old 06-04-2023, 06:51 PM
That is a risk with these older kits.
I finally got all the decals applied except the windshield banner. Putting a little Bilstein decal on that becomes three smaller pieces is supposed to be fun…?
The Following User Says Thank You to Scale-Master For This Useful Post:
mrgixxer (06-06-2023)
Old 06-06-2023, 08:40 PM
Now it's getting back on track… The clear should stabilize things. The hand painted red parts are significantly thicker than decals, and the clear does a good job of hiding that even a couple days after shooting, so I haven't decided if I will deal with that or not. Depends on how the clear cures.
Old 06-07-2023, 08:01 PM
I think the windows are supposed to be installed as one piece, but the left side windows didn't line up with the openings of the body. So I cut them apart.
They still don't fit that well, but they fit a lot better. Finally applied the last decal!
Old 06-08-2023, 11:32 PM
Despite all the troubles you've had, at least in the pictures the model looks nice and crisp. You can tell it's a small scale model as it lacks some details, but I like the result.
Old 06-11-2023, 08:04 AM
malscar's Avatar
you are doing very well with it. I very rarely leave the windows as one piece. Doing what you have although making it fiddly, does mean the end look is lots better. If you are wanting to reduce the amount of yellowing in the clear windows, get a jar, put some hydrogen peroxide in it then the windows. With a bit of sunlight you will see quite a difference. Just check regularily as if you over do it you can end up with them turning foggy. I test an off cut first to see how long it takes to get to the point I am happy. You can buy bottles of the stuff in chemist warehouses.
The Following User Says Thank You to malscar For This Useful Post:
Deathtrap (06-12-2023)
