Old 04-26-2023, 09:26 PM
prashant_akerkar prashant_akerkar is offline
Banned
Tyres Bursting at High Speed Highways in Summer season.
How the Tyres (Tube & Tubeless) can be prevented
from Bursting for the Cars running at High Speed Highways in Summer season?.
I mean what could be the preventive measures for avoiding the fatal accidents resulting to death or permanent physical disability
for the passengers?
1 Tyres maintenance pressure check at daily intervals.
2. Rubber Quality Wear and Tear out.
Old 04-27-2023, 05:28 AM
RidingOnRailz's Avatar
RidingOnRailz RidingOnRailz is offline
Re: Tyres Bursting at High Speed Highways in Summer season.
Everyone by now should know this.
And maintaining cold tire pressures at or up to no more than 3psi above vehicle mfg. specs is one of the best ways, along with checking treadwear, to prevent such incidents.
Old 04-27-2023, 10:39 AM
Banned
Thanks.
What could be the survival chances for the driver along with
the Passengers in the vehicle when facing such a situation?
The Driver is in a very difficult position to save himself along with passengers in the car.
Even Expert Skilled Drivers have a difficult task ahead in such a situation.
Isn' it?
Old 04-27-2023, 12:33 PM
Banned
Thanks.
I mean you faced this situation as a Driver. (USER EXPERIENCE)
Thanks & Regards,
Prashant S Akerkar
Old 04-28-2023, 02:14 AM
Banned
1 Controlling Steering Wheel
2 Not applying brakes suddenly
3 Alarming sound signals similar to Siren in Ambulance.
Anything else?
Old 04-28-2023, 02:57 PM
Banned
Thanks.
Are Siren allowed in your country for private owned vehicles?
In India, Fire Brigade vehicle, ambulance & police cops vehicles can install Siren - Sound system.
The Motor Vehicle Act, 1988, does not allow use of siren and pressure horn on any vehicle, except police, fire brigade and ambulance.
Old 04-29-2023, 11:16 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Originally Posted by prashant_akerkar View Post
Thanks.
This post does not pertain to the thread (started by you). If you're really curious about this, although I suspect the rules are pretty similar for civilized locations with good reason, please start a new thread.
-Rod
The Following User Says Thank You to shorod For This Useful Post:
RidingOnRailz (04-29-2023)
Old 05-04-2023, 09:37 PM
Banned
Thanks.
I feel while driving on highways, extra safety precaution would be carrying helmet by all the passengers.
Old 05-05-2023, 12:38 PM
shorod's Avatar
SHO No Mo
At highway speeds incidents happen too quickly to have the time to put on and properly fasten a properly fitting (ie: snug) helmet. With very few exceptions (none that I can think up) if a driver has enough time to put a helmet on, they have enough time to avoid the collision.
But how does carrying a helmet relate to a tire bursting? A bursting tire should not lead to a collision or loss of vehicle control unless the driver over-reacts. To that point though, I suppose someone prone to over-reacting may be the same type of person who would carry a helmet with them in a car....
-Rod
Old 05-06-2023, 09:46 PM
Banned
Thanks.
I mean the passengers apart from the driver (who is also a passenger is driving) wear the Helmet while approaching Highways or places where there could be accident.
For example : Mountain, Hill.
Can a Car driver wear a Helmet while driving in those accident prone areas?. Would it be useful?
Old 05-06-2023, 09:49 PM
Banned
Thanks.
If the Tyre/s burst in the car leading to accident, Could Helmet would have saved the passengers from head injuries?
Old 05-07-2023, 11:54 AM
shorod's Avatar
SHO No Mo
The extra mass of the helmets would likely lead to neck injuries unless the head is restrained and neck braces are also worn, such as in race cars. But then peripheral vision is restricted, which would likely lead to further accidents.
Do you have any specific, citable, data to suggest that head injuries from tires bursting is a real problem? And what is the leading cause of bursting tires? If tires typically burst from lack of maintenance or improper tire pressure, do you think drivers who fail to properly care for their tires are going to take the time to wear a helmet, neck brace, etc.?
-Rod
Old 05-07-2023, 08:12 PM
Banned
Thanks for the information on Neck braces.
Attached Neck braces images.
Wearing a Helmet and Neck brace by all the passengers in the car could add a extra safety caution in Accident prone areas as well as in Highways.
Last edited by shorod; 05-08-2023 at 07:59 AM. Reason: Removed unrelated, unncessary, neck brace images.
Old 05-08-2023, 06:41 AM
CapriRacer CapriRacer is offline
I'm sorry that I am a bit late to the party.
First, the actual burst pressure of a tire is many times the pressure normally used or what the max pressure written on the sidewall is. But tires can rapidly lose their pressure if damaged while operating, such as hitting an object. As long as tires are pressurized, this is a possibility.
In other words, there is no preventing tire bursting caused by road debris.
Much of the thread above concerns how to protect occupants of a vehicle due to a crash - regardless of if a tire is involved or not. Again, there is no preventing these things - only minimizing the effects.
Plus, there seems to be some posts missing. The OP seems to be responding to posts that aren't there.
But consider the case of a racing driver. They wear all kinds of things and the car is designed to mitigate the damage in a crash - and in spite of all that, there are fatalities.
In other words, how far does one go to protect passengers in cars? Maybe making them stay at home in a padded room? It's risk vs reward.
CapriRacer
Visit my website: http://www.barrystiretech.com/
Tags
accident , pressure , quality , summer. , tyres
