Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 04-08-2023, 09:55 AM
kiway22 kiway22 is offline
Send a message via Yahoo to kiway22
Smile Transmission fluid leak fixed.
I have had a transmission leak, for several years. The top tranny line (sending line) on the radiator, that runs under the valve body. Had rusted on the top, and was leaking. I cut the line on both sides of the leak, and installed a hose, made for transmissions. A gas line hose, will probably work as well. Because they are stronger, than a regular vacuum hose. After 2 weeks, I have seem no leaks. I will post back, if the the hose fail or something.
Old 04-08-2023, 11:50 AM
maxwedge maxwedge is offline
A990 racer
Re: Transmission fluid leak fixed.
Never use hose designed for anything but hydraulic use.
