Old 03-13-2023, 05:31 PM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
Honda CRF1000L Africa Twin
Next up, something simple, well by comparison to the Lola T70…
I'm building it straight out of the box, but not following the proper sequence as the instructions show because I wanted to see how the chain builds up. I considered getting the detail-up kit for the chain, but I thought I'd try to stick with the true OOB spirit just in case it looks good enough...
The kit provides a nice booklet of photos for reference and the instructions have detailed color call outs. However the two don't match on every item so I'm using both as a guide. The info for the chain falls in between the two.
Old 03-15-2023, 12:16 PM
Re: Honda CRF1000L Africa Twin
The rims are two pieces affairs and fit very well, but there is still a fine but unwanted seam where the halves meet.
The color called out for the rims is Gold Leaf but I thought the anodized gold look in the reference photos looked cooler so I used Titanium Gold under Clear Yellow from the LP colors.
The spokes after being painted.
Old 03-17-2023, 08:51 AM
The instructions on how to assemble the wheels is very detailed and specific even down to the cements to be used. The jig that is provided to lace the wheels works great.
They also instruct to use the same jig to install the tires; unfortunately it has three little ribs to center the rim that chipped the paint when I tried to install the front tire. Since the spokes were cemented into the rim I had to repair the paint damage as an assembled unit, so I made cardstock mask and blended the two colors.
I did not use the jig for the rear tire or for the front after I repaired the paint damage. The tires fit without too much effort onto the rims. I guess if you don't paint the rims the jig is a good idea for mounting the tires.
Old 03-18-2023, 01:54 PM
Like most motorcycle models I build, I do the brake rotors early on if not the very first thing. Since these came pre-drilled all I had to do was paint them. But that took a couple days with drying times.
Old 03-22-2023, 10:11 AM
Time to go to the beginning of the instructions and build on the engine.
I think I spent more time painting bolts than anything else and now I can see that some of the details will get covered by guards.
Old 03-22-2023, 01:35 PM
kans0002's Avatar
kans0002 kans0002 is offline
ohhhh - following!
Old 03-26-2023, 09:46 PM
The frame has been built up and painted. I used the recommended colors and was pleasantly surprised at how the color, sheen and texture came out.
The engine is a tight fit, but the instructions are clear on how to easily to twist it into place.
Old 03-27-2023, 03:28 PM
Mono shock.
Old 03-29-2023, 09:42 AM
Since I did a lot of painting before assembly, it built up pretty quickly and is getting to be a good size already.
The Following 2 Users Say Thank You to Scale-Master For This Useful Post:
michel1973 (03-30-2023), mrgixxer (03-29-2023)
Old 03-31-2023, 02:29 PM
Swing arm.
Old 04-04-2023, 05:07 PM
It builds up pretty quickly, if you do a lot of paint work ahead of time…
Old 04-05-2023, 10:17 AM
There's a good amount of time invested in the radiators and fans, but I suspect they won't be seen when the model is done.
Old 04-06-2023, 12:39 PM
I thought I should get some of the six "body" panels painted so they could be drying while I build other parts. (I'm going to need the front fender soon.)
TS-45 Pearl White over TS-26 Pure White. I shot a coat of TS-13 Clear too. Can't hurt before the decals…
Old 04-07-2023, 09:11 AM
The forks are mostly metal and functional; they have springs in them too.
mrgixxer (04-11-2023), Petersm99 (04-11-2023)
Old 04-08-2023, 12:53 AM
CifeNet's Avatar
CifeNet CifeNet is offline
Great progress! Very clean and well executed! Being 1/6 scale, things do look more realistic too.
-- CifeNet
