Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 03-09-2023, 10:20 AM
M2Tshort4Matt M2Tshort4Matt is offline
HELP! 2011 malibu 2.4 IDLE SPEED HIGH,ENGINE POWER REDUCED, LOW TRAC, SERVICE ESC, P1400,P0507
My 2011 Malibu all the sudden started idling high, I assume it then switched to limp mode as the dummy lights came on. It was shuddering violently a stop. Long story short I cleaned the throttle body, Which didn't help so I replaced the throttle body and the spark plugs clean the map sensor and the intake I'm at a loss....... Can someone help please thank you in advance!
Old 03-09-2023, 02:19 PM
maxwedge maxwedge is offline
A990 racer
Re: HELP! 2011 malibu 2.4 IDLE SPEED HIGH,ENGINE POWER REDUCED, LOW TRAC, SERVICE ESC, P1400,P0507
Welcome to the forum. For starters, https://www.way.com/blog/how-to-fix-a-p0507-code/
Old 03-09-2023, 08:25 PM
harleyguy harleyguy is offline
Do you know what codes you have? Maybe take it to an auto parts place and have them pull codes.
It sounds like you might have a vacuum leak.
Old 03-10-2023, 03:52 AM
SCBeachyKeen SCBeachyKeen is offline
Send a message via ICQ to SCBeachyKeen Send a message via MSN to SCBeachyKeen Send a message via Yahoo to SCBeachyKeen
Sounds to me like a battery or alternator issue.
Tags
p0507 , p1400
