Go Back   Automotive Forums Car Chat > Mercury > Mountaineer
Old 03-02-2023, 01:54 PM
JJR2 JJR2 is offline
MAF wiring may have shorted out
2008 Mountaineer, V6, AWD
The last couple of inches of the wiring for the MAF sensor connector must have been exposed the heat over the last 190k miles, and crumbled. The wiring probably shorted together before I found it. Is it likely the sensor was damaged?
Old 03-02-2023, 03:48 PM
maxwedge maxwedge is offline
A990 racer
Re: MAF wiring may have shorted out
Wont know tiil you fix the harness.
Old 03-02-2023, 06:01 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Agreed; repair the wires first; the sensor could be perfectly good and no reason to replace it if so.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 03-02-2023, 06:46 PM
I repaired the harness. The engine runs and drives normally. I just want to try to avoid another disappointment after 70 miles.
Old 03-02-2023, 06:52 PM
There you go - the sensor works; so in your place I'd just drive it.
I don't think that a sensor is sensitive to power surges...after all, there's one every time you start the engine. Either it's good or it's not.
Logically, having the wiring get fried due to a short circuit means "short circuit" and the voltage never reached the sensor anyway.
But that's just; if you're worried about it and the $$ won't bother you, then replace it now.
Except: I've seen cascading sensor failures on older vehicles...the new electrical parts are, for lack of a better term, "stronger" than the older ones, so the older ones fail. Once replaced, THAT new sensor causes another to fail, etc. So on a 2008, I'd leave it be.
