Old 02-15-2023, 10:35 PM
icantfixcars icantfixcars is offline
Air Compressor tube adapter on my car doesn’t seem to match replacements
So this is a two parter. I’ve been replacing my suspension components, and my car is still not quite riding as smoothly as I suspect, It obviously sits lower now on the back and it bumps harder on the back when that part of the car goes over bumps so I know my fronts now fine and my rear is the main issue now.
I bought rear shocks because theres some decent brands with cheap replacements, but when I was unscrewing the old ones from the top I noticed that the tube from what must be the air compressor ends in a hex threaded end which threads onto the shocks, but the models I bought while similar in every other way have a push on connector presumably with a clip and no adapter option.
My first question is, Why can’t I find air shocks with my threaded ends to fit my air compressor fitting or one with an adapter, all the ones online appear to have the same barb sort of fitting, can anyone direct me to an option that will fit a threaded end??
My second Question is if I do end up getting new shocks on this car and it still bounces, does that narrow it down to the air compressor itself and if so am I better off just getting the types of shocks with only coils? It would be annoying to have to shell out for an air compressor, there doesn’t seem to be any cheap options and if there were I’m not sure I’d want them.
Thanks!
Old 02-16-2023, 08:15 AM
maxwedge maxwedge is offline
A990 racer
Re: Air Compressor tube adapter on my car doesn’t seem to match replacements
Rock auto has the right shocks with the adapter line kit and fittings. Used this kit on my 2003 Park. The shocks will correct the bouncing, but the level ride system may be bad, which would cause the car to sit low in the rear.
