Old 01-21-2023, 04:23 AM
Bokkie Bokkie is offline
Faulty Drive Gear TURBO 350
I am looking for advice as my Drive Gear keeps moving on the main transmission shaft, twice the retaining clip broke the tab off in addition 8 times the Drive Gear moved back 1/2 an inch, I've tried different drive gears & different driven gears & different housings & always the same result it works for 5 minutes and then the needle drops.
i would appreciate any advice if someone else has had this problem or just knows what i could do as I'm over jacking the car up and removing the Tail shaft and extension housing.
Help !!
