Old 01-01-2023, 05:40 PM
sierra3dr sierra3dr is offline
Distributorless Ignition Modules
Hello all,and Happy New Year. I was wondering what each Marque used back in the 90s when manufacturers were phasing out ignition distributors? For example Ford have EDIS.
Old 01-02-2023, 08:58 AM
Blue Bowtie's Avatar
Registered Offender
Re: Distributorless Ignition Modules
Prior to DIS, GM had used a trade name "HEI" (High Energy Ignition) since the 1974 model year. But GM applied no trademark name for their distributorless systems, dating back to 1984 when it was simply identified as "DIS" for the Buick 231 cubic inch engine (that one should be familiar in the U.K. since it was used by Rover until 2006). There have been a number of changes based upon engine architecture, but a trade name was not applied to the systems to my knowledge.
There was an "Opti-Spark" system used on the LT1 and LT4 V-8s in the 1990s, but that was actually a distributor system.
Old 01-03-2023, 06:15 PM
RidingOnRailz's Avatar
RidingOnRailz RidingOnRailz is offline
Cool Re: Distributorless Ignition Modules
Which certainly muddies the waters...
So when I toss up the hood of any car, what clues me in as to whether that vehicle has a distributor or distributor-less ignition system?
Old 01-03-2023, 06:59 PM
maxwedge maxwedge is offline
A990 racer
Lightbulb Re: Distributorless Ignition Modules
Obviously if you see a distributor the question is partly answered. If you see plug wires going into a coil pack. Then it is a dis system.
Old 01-03-2023, 07:55 PM
What would my 1981 Buick Century have been. I did see something round with wires coming from it under the hood.
Old 01-03-2023, 08:37 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Unless you're 1981 Century had a diesel engine it would have had a distributor. It was likely GM's HEI distributor with the coil mounted in the top of the distributor cap.
-Rod
Old 01-04-2023, 03:07 PM
-Rod
Thanks for sparking my memory! Yes, I did see HEI in the service manual I bought for that car when I owned it. For some reason I thought HEI and a distributor were two separate things.
Old 01-04-2023, 06:36 PM
shorod's Avatar
SHO No Mo
I think GM just decided it could be called "high energy ignition" because they didn't have the added loss of a coil wire.
-Rod
Old 01-05-2023, 01:45 PM
Excellent answer 👍
