Old 12-20-2022, 06:01 PM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
2000 GTR Skyline
Something simpler to tinker on while I wait for stuff to dry on other projects. I have a basic plan…
Mostly I've just been cleaning up the parts and shooting some of them when I'm painting the same colors on other parts. But since I had the body prepped I went ahead and shot it TS-56 Cheeze Wiz.
Old 12-21-2022, 07:17 PM
Re: 2000 GTR Skyline
Most of the engine has been assembled.
The Following 2 Users Say Thank You to Scale-Master For This Useful Post:
fafnir (12-22-2022)
Old 12-22-2022, 09:59 AM
I spent more time painting the belt and pulleys than any other part on the engine.
I had to use the factory Sky Blue for the one pulley.
Old 12-22-2022, 07:34 PM
ChillyB ChillyB is offline
I love this car and this kit. It looks great in that color.
Old 12-24-2022, 10:14 AM
Thanks!
The chassis is coming along.
Old 12-26-2022, 01:32 PM
The bottom of the chassis is done. At least for now…
Old 12-27-2022, 04:26 PM
I didn't like the connection of the header to the exhaust. So I "welded" them together.
mrgixxer (12-29-2022)
Old 12-29-2022, 10:45 AM
The engine bay is pretty much done.
Old 12-30-2022, 10:50 AM
Flocking/carpet didn't seem to fit the theme so the floor of the interior was sprayed with textured dark gray to simulate a rubberized coating.
The rest of the parts were painted as called out in the instructions, sort of… I swapped Medium Gray for the Black inserts. The silver and gray are brush painted.
Old 01-03-2023, 10:28 AM
The dash is done too. I used the same painting technique for the wood grain as I did on the console.
The Following User Says Thank You to Scale-Master For This Useful Post:
Mpfiend (01-04-2023)
Old 01-03-2023, 01:52 PM
fafnir's Avatar
fafnir fafnir is offline
Real nice work so far.
Old 01-04-2023, 10:56 AM
Thank you!
The shoulder harnesses are shown in the instructions to be attached to the bottom of the front seats, but I decided to attach them more like I did on my real car and anchor them by the back seat.
Test fitting the body…
Old 01-05-2023, 10:54 AM
Note to self. Install the delicate tie rod after installing the body for the final time. I drilled the ends of the part and will fix with a steel pin.
Old 01-06-2023, 10:34 AM
I'm good with this repair. I had to sand just a little bit after cementing the pin in. Then I brush repainted the center section.
Old 01-07-2023, 11:14 AM
So much for painting the body early and letting it dry for a while… I was happy with both the color and the finish of the Bright (Cheez Whiz) Orange, but after working on the tug I decided I liked the Camel Yellow even more for it. It also fits the inspiration for this project better, the BRE BrockBuster 510.
