Go Back   Automotive Forums Car Chat > Fiat > 500 | 600 | 126 | Bambina | New 500C
Old 09-30-2022, 08:27 AM
andrei2000pc andrei2000pc is offline
Exclamation Fiat 500 2013 Won't start
Good morning. Thank you for reading this.
I have a Fiat 500 2013, nearly 200,000 miles on it.
Oil, coolant and transmission fluid have been changed.
The coils have been replaced a year ago.
This problem I am mentioning has happened before all this.
When I put my key in, it will start the starter with the engine turning over but does not kick in as it seems lack of gas. After repeating about 4 times, then the starter will not kick, and I just get electrical clicking noises with dashboard lights not loading properly. I have not checked the voltage on the battery. I connect my car starter and still no luck.
Is this a bad starter? This is like the 5th time I have had this problem. Eventually the car will turn over and start running perfectly for some time.
Old 09-30-2022, 09:50 AM
Exclamation Re: Fiat 500 2013 Won't start
Just saw this video. Going to try it. Sticking a rod down the oil fill valve. Something to do with the multiair.
https://www.youtube.com/watch?v=8aJuiVhgsNw
