Old 08-17-2022, 10:19 AM
Puterwiz82 Puterwiz82 is offline
Auto locking doors
I have a 2009 Honda Accord EX that was unlocking the driver side door when put in P, and if the doors were unlocked, it would auto lock them over 9 mph. It is no longer doing that. How do I fix this?
Old 08-17-2022, 08:01 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Auto locking doors
Owner's manual should say.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 08-17-2022, 08:05 PM
I have tried re-programming it based on the manual but it still does not work.
Old 08-17-2022, 08:35 PM
Hmmm...well it could be a short or other electrical issue; but I've heard of stuff like this being caused by odd voltage - either old battery or corroded cables - or it might be the system needs to be reset.
I would first try disconnecting the battery and holding the 2 battery connections together. This should drain all the voltage and reset everything.
While doing that, check the cables for corrosion. I once found corrosion gong back about 22cm from the battery, INside the insulation. Then make sure all the connections are tight.
Old 08-18-2022, 06:35 AM
I will give that a try. Question though, would I lose the stored key chip in the ECM or no? If it does happen, then I'd have to have it towed to the dealer since I wouldn't be able to start it.
Old 08-18-2022, 11:14 AM
Don't know for sure but I'd guess not. Maybe look up the learn key procedure on youtube.
Tags
auto , lock
