Old 07-05-2003, 08:11 PM
er97civic er97civic is offline
97 Civic will not start
Any help out there would be appreciated. I have a 97 Civic that cranks but will not start. I have replace the distributor cap, plugs and wires. I know its not the battery because all lights and radio work. I have pushed started the car and it worked for a few weeks but it started doing the same thing today. I have been reading over the forums and am going to try and read the ecu codes.
Can anyone tell me were the ECU is located on this model..
Thanks in advance
Old 07-05-2003, 09:14 PM
candlaudio candlaudio is offline
Send a message via Yahoo to candlaudio
well i know on my 94 the ecu is on the passenger side under the dash on the side wall, ummmmm maybe that will be had to figure out so do this sit in the passenger seat and look by you right foot and it should be under the carpet, try there and if it isnt there then look under the seats.... hope you find it
Old 07-06-2003, 01:06 PM
Alright, I was able to find the ECU unit. I jumped the only two holes on the blue connector and turned the ignition key to on. The check engine light does not blink and I do not see any LED on the ECU unit. The unit is the P2E. Anyone have any suggestions.
Also, Ive been reading and saw other people with similar situations. They talk about it being the ignition coil and other things. Anyone know where I could find some type of diagram that describes were all this stuff is located on the engine. I dont have a clue
Thanks for the help
Old 07-06-2003, 01:12 PM
edman24 edman24 is offline
Send a message via AIM to edman24
best thing for you to is buy a haynes manual. i think autozone carries them. find one for your car and it will have all the info you will need on every system in your car. sounds to me like your fuel pump is gone or your ignition coil is bad. but check it out.
I feel bad for those who pay twice as much as i did for my car and still lose to me. The sorrow in their face is enough to bring me to tears.
