Go Back   Automotive Forums Car Chat > Hyundai > Santa Fe > MY 01-06
Old 05-04-2022, 08:30 PM
harleyguy harleyguy is offline
CV shaft broken
My 16 year old bought a 06 Santa fe 2.7L Fwd 180xxx miles. He had ABS problems. Found the tone ring on the driver's cv shaft was broken and slipping out of place.
I replaced the shaft (autozone) Two weeks later he called "it made a clunk and now acts like it's in neutral" I looked it over. The new cv shaft fell out. Turns out it broke the tip off and retaining ring. Marked it down as a fluke and replaced it again.
Now three months later it did it again. What could be causing the shaft to break the retaining ring off like this?
Old 05-06-2022, 11:08 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: CV shaft broken
Sometimes manufacturers will redesign parts...if it was not quite an exact fit it could break off.
It also could be a weak aftermarket part (hopefully under warranty!)
I would take the original if you by chance still have it, and try an OEM part.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 05-07-2022, 07:30 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: CV shaft broken
Could your son be doing burnouts and causing axle problems?
Old 05-07-2022, 04:34 PM
Re: CV shaft broken
That was my thought was just a bad quality. I do not have the original one. When I replaced it it did look the same side by side. Yes it's a lifetime warranty, and a easy job replacing it.
His driving was one of my thoughts too. However I would think aggressive driving would brake the shaft outside of the trans and not inside where it's splined together.
