Go Back   Automotive Forums Car Chat > Cars in General
Old 04-25-2022, 12:11 PM
tirenoob tirenoob is offline
Are these tires properly mounted?
I recently replaced had two tires replaced on my wife’s 2006 Toyota Corolla. She complained that they looked a little flat. The air pressure seems okay, 30 psi, but they do seem to bulge at the bottom. They also seem a bit further back on the rim then previous tires we have had. I can see maybe a pencil’s width where before it was maybe half that. Does anything look like a concern? Thanks!
https://imgur.com/a/IUAJFNP
The Following 2 Users Say Thank You to tirenoob For This Useful Post:
thomaswhite (06-15-2022)
Old 04-25-2022, 01:11 PM
maxwedge maxwedge is offline
A990 racer
Exclamation Re: Are these tires properly mounted?
That outer tire bead does not look seated. Who mounted the tires?
Old 04-25-2022, 03:20 PM
CapriRacer CapriRacer is offline
I see you posted here as well as Car Talk. Here's what I said over there:
First, those look fully seated to me. I think we're looking at the difference in lower sidewall shape.
Second, even if they aren't fully seated, there enough force in the air pressure that a little bit of driving will seat them.
CapriRacer
Visit my website: http://www.barrystiretech.com/
Old 05-22-2022, 07:48 AM
Vanman1720 Vanman1720 is offline
If you look close to the edge of the rim the tire generally has a line that is molded into it. This line you can follow around the wheel and verify that the bead is seated correctly, most tires I have seen have had a similar line like this as part of the tire.
