Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '04+
Old 03-25-2022, 08:14 PM
Hurricane145 Hurricane145 is offline
2014 Jetta Trunk Lamp Problem
I have a 2014 Jetta that I replaced the original trunk lamp that burned out with a new LED lamp. It still does not work. The trunk does get a lot of open/close use. I understand there is a switch that controls the trunk lamp in or around the trunk latch. Is it likely the problem or should I look elsewhere? Is there a way to test it?
I don't think it is a fuse as I would expect other things are run off the same fuse and everything else on the car works okay.
Any advise would be much appreciated!
Thanks, Mike.
Old 03-26-2022, 11:59 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: 2014 Jetta Trunk Lamp Problem
Did you try reversing the LED bulb? A lot of LED's are polarity sensitive.
Old 03-26-2022, 01:30 PM
I'll give that a try. The bulb was a really tight fit and difficult to get into the holder. I'll check tor voltage at the lamp too.
Old 03-26-2022, 03:28 PM
Checked the voltage and it was okay so popped out the lamp and turned it around like you suggested. Works fine now! Thanks for the tip!
