Go Back   Automotive Forums Car Chat > Pontiac > Aztek
Old 02-24-2022, 12:22 PM
frog_girl frog_girl is offline
Power Locks & Windows Went Out
I have a 2003 Aztek that I've driven since 2018. A few months ago, I was driving and had to hit the break pretty hard to avoid a crash. Immediately after this, my "service vehicle soon" light came on and the power locks, windows, and cruise control all stopped working. I thought a fuse had blown but all of my fuses are fine, and the cruise control LOOKS like it should be working fine, just isn't. I haven't had any other unusual or major issues since this has happened, but can't seem to figure out what is causing this. Any info or suggestions are greatly appreciated!
Old 02-25-2022, 12:34 PM
Blue Bowtie's Avatar
Registered Offender
Re: Power Locks & Windows Went Out
It may be helpful to scan the vehicle and check for CAN bus communication between the serial modules. It could be that the PCM can't signal the body control, door modules, ABS/traction, and other systems.
Old 02-26-2022, 06:49 AM
autojoe autojoe is offline
2003.... When did can start? Class 2?
Old 02-26-2022, 06:54 AM
Thanks! If this is the issue- what would the fix?
Old 02-26-2022, 07:30 AM
Registered Offender
I know the '03 Saturn and some Buick/Cadillac had CAN, and by 2006 everything used it. Not sure of the Aztec/Rendezvous platform.
Old 02-26-2022, 07:33 PM
Your have to get a full system scan report back all stored trouble codes.
Old 02-26-2022, 07:39 PM
What size engine? All windows don't work at door switches or master switch? Plus all locks and cruise control? Check engine light on?
Old 02-26-2022, 07:40 PM
I will look at wiring schematic. If mil is on get code scan and report back all module codes.
Old 02-26-2022, 08:16 PM
3.4 engine? Need to know if you can operate door locks and power windows from master control switch and from each door switch. Report back results.
Tags
locks , power
