Go Back   Automotive Forums Car Chat > Buick > Regal
Old 02-14-2022, 12:57 PM
bg819 bg819 is offline
How do I get this hose off?
Hi All,
I have a 2011 Buick Regal and I am trying to remove the Valve Cover. There is a steel braided hose on the back side of the valve cover that I can not figure how to take off. Anyone know how this is removed and what the hose is called? Thank you.
Old 02-16-2022, 03:31 AM
autojoe autojoe is offline
Re: How do I get this hose off?
Is that turbo oil return pipe? What size engine?
Old 02-16-2022, 03:56 AM
On the Turbo end of the line, remove the 10mm screw and then pull the entire fitting out of the Turbo housing. The disconnects are not mean to be released. The fitting is in there with an O-Ring that may be difficult to release. Just keep pulling and it will give. Replace O-Ring upon reassembly.
Old 02-16-2022, 04:19 AM
I would spray with some sort of lubricant near engine where hose connects to the engine wiggling and pulling hose at same time could even take a thin putty knife try to pry it also. Should be 2 orings on end of the hose
Old 02-17-2022, 09:25 AM
I took the screw out but it's still stuck. I'll try again this evening.
Old 02-22-2022, 12:40 PM
Did you get it off?
Old 02-22-2022, 01:14 PM
Yes I did. Took some serious pulling though. Thank you.
The Following 2 Users Say Thank You to bg819 For This Useful Post:
autojoe (02-22-2022)
