Old 12-15-2021, 04:41 PM
RedHeadedGuy RedHeadedGuy is offline
Angry 88 Blazer 4.3 idle issue after head gasket replacement
I replaced head gasket, and all gaskets up. Fixed vacuum lines, had to time off timing chain alignment. no timing marks, tab missing. I can get to start right up, then idles really high then surges really quick a little higher rpm, also has sputtering to it. What Should I do now?
Old 12-15-2021, 04:43 PM
Re: 88 Blazer 4.3 idle issue after head gasket replacement
Also Distributor was little rusty, and i cleaned all the heavy build up out of tbi
Old 12-15-2021, 04:56 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
If its idling high and surging it sounds like you have a vacuum leak.
Old 12-15-2021, 06:53 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
+1 on the vacuum leak.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 05-12-2022, 02:05 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Check your Intake Manifold Gaskets while at Idle by spraying WD-40 or Carburetor Cleaner around the Gaskets, and anywhere else where a leak might be found. If you have a leak, you should hear the engine Rev a little when sprayed.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
