Old 11-23-2021, 04:27 PM
Burksy Burksy is offline
New brake shoes
Hi, I just replaced the rear brake drums, shoes, wheel cylinders and hardware on a 96 F150. I know they take a little time to bed in but they seem tight. I adjusted the self adjusters all the way in. All put together the wheels are hard to turn by hand. Is this normal?
Old 11-24-2021, 06:24 AM
65comet's Avatar
65comet 65comet is offline
Re: New brake shoes
After a hundred miles they should spin pretty freely by hand. If not, take the drums off and put the wheels on the axles and spin with no brakes to make sure it isn't the wheel bearings or something in the rear axle housing. If it spins fine there, try adjusting the spinner adjuster wheel in a bit more if it will do it. Make sure you have the shoes on correctly. There are sometimes two sizes, so make sure you don't have the two larger on just one side, and also if there are two sizes, one goes to the front and one to the rear, but I either mark which went where before taking it apart, take a pic, look it up online or just make sure once on that it has the correct spacing all the way around.
The Following User Says Thank You to 65comet For This Useful Post:
Stealthee (11-24-2021)
