Go Back   Automotive Forums Car Chat > Hyundai > Elantra | Avante
Old 11-02-2021, 04:00 PM
fernandoleon88 fernandoleon88 is offline
Do I need a new wheel bearing? If yes... which one is the best for my car?
Hi. I have a Hyundai Elantra 2009. Recently my mechanic installed the front shocks and aligned my car. Then I noticed the car was going to the right on its own. If I pressed the brake, it also goes to the right roughly.
He checked the brake pads and rotors which have like 2 months of use and they were fine. He rotated the tires and all 4 tires have 32 PSI too. Then he bleed the brake line. but the problem wasn’t solved. So he told me to replace both brake hoses and calipers and I did, but still the problem persists.
I noticed that the steering wheel is a bit wobbly and when I go over 25 mph the car starts to shake a bit. Sometimes, when the I start my car cold and make the first turn, it will have like a “hum” sound from the right side and then its gone. I read online that maybe the problem is the wheel bearing. So I jack up the car, moved the tire vertically and horizontally and has no play… its solid. So I don’t know if its the bearing or not.
I have never changed a wheel bearing, but I will do it myself since I am on a limited budget, but if so, which wheel bearing do you recommend? I want a good quality one that won’t break in a year or two.
Thanks in advance.
Old 11-03-2021, 06:44 AM
CapriRacer CapriRacer is offline
Re: Do I need a new wheel bearing? If yes... which one is the best for my car?
I don't think this is a wheel bearing problem. It sounds like an alignment issue.
Did you get a print out? What does it say?
FYI: It is common for alignment techs to think that if the factory didn't provide adjustment, then you don't need to or can't adjust. Not True!! Sometimes it takes a camber plate or an eccentric bolt (extra cost!), which may be why the consumer isn't informed they have a problem.
CapriRacer
Visit my website: http://www.barrystiretech.com/
