Old 10-25-2021, 06:36 AM
feldkij feldkij is offline
Faults on dash cluster and other fun happenings!
2015 F-150 Platinum, 110,000 miles.
Two faults appeared on the dash cluster one after the other, blind spot monitor and cross traffic alert are indicating to be turned off. A navigation fault appeared on the main console screen. The climate control is unresponsive (no A/C, Heat or blower) as well as the radio controls (steering wheel controls for radio still work). I also noticed only the Front windows are in-op and the running boards no longer deployed upon opening the door. I checked the settings and sure enough the running boards switched themselves off and won't turn back on to auto.
I did a factory reset on the main console screen. I pulled the battery, waited a half hour before hooking back up. Same results. The diagnostic reader indicates there is an issue with yellow exclamation point but can't read any codes.
Dealership Service depts. are backed up for two weeks.
Is this something anyone has seen before? Is this definitely a dealer only fix?
Just wondered if there is something I can do or try while I am waiting for the dealership appt. The worst part is not having a defroster or heat.
Thanks again for any help.
Old 10-25-2021, 02:50 PM
65comet's Avatar
65comet 65comet is offline
Re: Faults on dash cluster and other fun happenings!
I have the 2015 F-150 Crew Cab 4x4, but it doesn't have any of those options. I suggest putting the question out to a bigger F150 2015-2020 Forum specific to the truck as you could possibly get a faster answer there.
https://www.f150forum.com/f118/
Tags
blind , cluster , cross , fault , running
