Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 10-13-2021, 01:51 PM
dirtymazda dirtymazda is offline
Extended start. Everything is new
I’ve been tinkering with this truck for 3-4 months now. I got it running pretty good I think, but, it still has an extended start. Here’s a breakdown of what was done so far. Ive replaced the following:
Fuel pump
Fuel filter
FPR
All 8 fuel injectors
Spark plugs
Wires
Distributor
Distributor cap
Rotor
Pickup
Coil
Ignition module
Crank sensor
Throttle position sensor
MAF sensor
Cleaned the IAC
Cleaned the throttle body
It’s currently throwing a P1345 code that keeps coming back. Ive done a relearn on a brand new crank sensor also. Any ideas?
Old 10-13-2021, 05:13 PM
aleekat aleekat is offline
Re: Extended start. Everything is new
Year & Engine?
Post back, that's what makes Forums Work.
Old 10-13-2021, 05:27 PM
Yea I guess that would’ve helped if I put that in.
It’s a 1999 GMC K3500 with a 7.4
Old 10-13-2021, 09:01 PM
P1345 is a crank/cam correlation code. Other than the distributor that’s been replaced twice I never messed with the timing. I made sure the distributor was timed dead on when I put it back together. I triple checked it. This code never showed up until I replace the intake gaskets, fuel injectors and fuel pressure regulator
Old 10-14-2021, 10:36 AM
Figured out the problem. I had the rotor pointing to the number one cylinder, should’ve been pointing to the engraved “8” on the distributor itself instead like a traditional small block. Starts faster now and runs great
