Old 10-03-2021, 04:51 PM
wirlybird wirlybird is offline
Electric Fans For 1997 K3500 W/454 Vortec?
Me again!
I have read that switching over to electric cooling fans on this truck can add a little performance and mileage.
Is this a worthwhile update?
If so any recommended suppliers/kits?
Thanks!
Old 10-04-2021, 07:47 AM
Blue Bowtie's Avatar
Registered Offender
Re: Electric Fans For 1997 K3500 W/454 Vortec?
I have seen those comments and read those stories as well. It's good that you're doing research before jumping in with both feet.
1. GM was installing electric fans in vehicles long before 1997. It's not only a fan, but a system. In some applications, electric fans can make sense.
2. If there is any engine that would struggle turning a mechanical fan, it is NOT a 454. It idles with probably more torque than many 1.8L, fourteen-camshaft, 30 valve per cylinder, go-kart engines make at full throttle.
3. Electric fans merely move the load from the water pump hub to the alternator (and wiring), and add inefficiency in the process.
4. Nothing, electric fans included, is more effective than a properly sized, properly ducted, and properly functioning mechanical fan with a hydro-viscous clutch for cooling - In my opinion. You can ADD an electric pusher fan for cooling without creating a problem, but removing the stock plastic clutch fan and shroud will likely create more problems than it solves, and will result in a net zero gain in performance and fuel mileage.
Search around some other forums. Look at what happens in S-trucks, Trailblazers/Envoys, and similar vehicles if/when electric fans are retrofitted and mechanical fans removed.
The Following User Says Thank You to Blue Bowtie For This Useful Post:
Schurkey (10-04-2021)
Old 10-04-2021, 08:02 AM
Thanks for the common sense info. Had to chuckle at this and couldn't agree more!
"struggle turning a mechanical fan, it is NOT a 454".
On one hand I understand the theory behind removing the mechanical fan for a HP/performance gain, kind of like don't run the A/C!
I also think electric fans would put minimal load on the electrical.
With all that said I do agree that the factory system is pretty proven.
If converting to electric fans will realize negligible performance gains then it is not worth the cost.
I'm sure there will be other ways to gain performance/HP that are more benificial.
Old 10-04-2021, 08:29 AM
Schurkey Schurkey is offline
Originally Posted by wirlybird View Post
I also think electric fans would put minimal load on the electrical..
You need to check out the fuse sizes on the bigger electric fans. They suck electrical power like mad.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
