Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 09-09-2021, 06:19 PM
shakee shakee is offline
engine bogs, no check eng. lite
2003 explorer starts but when u press on gas it bogs down. idle is somewhat rough. no check engine lite, so no codes. i replaced maf, fuel pump, fuel filter, egr valve, ckecked for plugged exhaust, cleaned air intake assembly. what should i try next?
Old 09-10-2021, 12:28 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: engine bogs, no check eng. lite
Even with no check engine light illuminated, it could still have pending diagnostic codes.
You don't mention checking for vacuum leaks, so have you checked for vacuum leaks?
-Rod
Old 09-10-2021, 09:04 PM
i checked for vacuum leaks and found none. i noticed smoke coming from back of motor near where i believe pvc valve is located. could my pvc valve be plugged up and if so would it cause my motor to run the way i described it was running?
Old 09-12-2021, 08:57 PM
shorod's Avatar
SHO No Mo
If the PCV valve has a rubber elbow, those have been known to crack on multiple other Ford products and cause a vacuum leak misfire.
-Rod
