Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '01-'05 Civic
Old 07-31-2021, 11:13 AM
weichmeier weichmeier is offline
05 Civic COUPE Passenger Window Will not Go Down
In my 05 civic coupe, the window randomly stopped working. I do not remember hearing a noise of any sort and it wasn’t wet when it stopped working, but now it will not go down and it will only go up. I checked all the fuses, looked fine. I replaced the window motor and regulator, and nothing changed. I actually bought a motor without a regulator and when attached, the gear only moved when it went up. I also replaced the master switch on the drivers side and nothing changed. I also reset the master switch. I’m completely lost.
Old 08-01-2021, 09:06 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: 05 Civic COUPE Passenger Window Will not Go Down
I don't know if it is an issue in Civics per say, but you may want to check the wiring harness as it runs through the door jam. A broken wire could cause what you are experiencing. If you don't find anything there you are going to have to bust out a multimeter and get the wiring diagram for the door and do some diagnostics.
Tags
civic , coupe , passenger , window
