Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 06-17-2021, 03:59 PM
Rookie#1 Rookie#1 is offline
Question 2012 RAM Fuel rail noise
2012 Dodge Ram 1500 5.7L truck. Recently I started noticing the fuel rail on both sides are becoming very noice. No codes and truck runs out good on the road. Anyone have a solution.
Old 06-17-2021, 04:30 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: 2012 RAM Fuel rail noise
What do you mean the fuel rail is noisy? The fuel rail has no mechanical parts. If you are talking about injectors ticking it is normal.
Old 06-17-2021, 05:18 PM
Not a tick. Sounds almost not a nock with a rythem at idle. Loud enough be concerned while standing to side of the truck whith hood closed.
Old 06-17-2021, 09:02 PM
Stealthee's Avatar
No knock is coming from the fuel rail. I wonder if you have a collapsed lifter.
Old 06-22-2021, 10:41 AM
I've run a stethoscope around the motor, altenator, pullys, valve covers, intake, etc.
Opened oil cap and it all comes to the injecter rails. Not a solid nock and not a tick. Hard to define. Due to medical conditions the truck sat in the garage most of the time for the past
9 months. Took it out around a month ago to do a manifold job and that's when I started noticing the noise.
Old 06-22-2021, 04:04 PM
Stealthee's Avatar
Again the only ticking that could be coming from your fuel rail would be the injectors cycling. The rail itself has no moving parts. It's just tubed with holes.
Old 06-25-2021, 05:51 PM
I was thinking more along the lines of fuel pressure fluctuations as injectors fired. Bare with me I'm new to this 5.7 beast. Much to learn about it's bad habits. If it's in the valve system we will find it but so far I'm not completely convinced that's where my problem lay's. What ever it turns out to be I'll keep all posted.
