Go Back   Automotive Forums Car Chat > Dodge > Ram Van
Old 06-01-2021, 06:52 AM
Eddy1 Eddy1 is offline
Van stopped running, then ran very roughly
I was pulling into a parking lot and my van quit running, I coasted into the parking lot and got it started and running just enough to pull to the side, it ran like it was running on one cylinder very rough no power at all. Then I could not start it again. While waiting for the tow truck I put my phone on charge and realized both cigarette lighters had no power, I dont know if it related or not, any ideas what to check?
Old 06-01-2021, 09:41 AM
alloro alloro is offline
Re: Van stopped running, then ran very roughly
Originally Posted by Eddy1 View Post
While waiting for the tow truck I put my phone on charge and realized both cigarette lighters had no power, I don't know if it related or not, any ideas what to check?
Start with checking the battery and charging system.
Old 06-01-2021, 11:12 AM
Battery was still good. I did crank over a fair bit afterwards. Could the charging system cause this issue?
Old 06-01-2021, 11:46 AM
I have noticed in the past after I let the battery go dead a few years back,(its new now) I had to get the jumper cables out and get a boost, even after the van was started if the battery wasn't strong enough when the boaster cables were removed the van would stall. Maybe this is normal for newer cars, but if i did this with my old datsuns you can remove the battery cable completely and the car would keep running, my van woundnt even run if the battery is not charged enough let alone remove the battery cable. I always thought that was odd, is this normal?
Old 06-01-2021, 11:52 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
If it's shutting off when you remove the jumper cables it sounds like the alternator isn't working. A battery in a car is mainly for starting. Once started the alternator keeps it running.
Old 06-01-2021, 12:10 PM
Yes thats the way I have always known it too. But its done this for years and it does charge, once I put the new battery in it was no problem
Old 06-01-2021, 01:12 PM
So I put it on charge all day, it tuns over quickly but there no sign of firing at all.
Old 06-11-2021, 02:46 PM
I got some starting fluid and squirt it into the intake and no sign of a fire at all, any ideas? Hopefully you guys can offer more suggestions .
Old 06-11-2021, 06:52 PM
aleekat aleekat is online now
Year, model, engine?
Post back, that's what makes Forums Work.
Old 06-12-2021, 08:08 AM
Sorry its a 2003 1500 van 5.9L
Old 06-12-2021, 09:07 AM
Sounds like no spark. Maybe crank sensor?
Old 06-12-2021, 12:43 PM
Pull the wire from the center of the distributor cap and use that to check for spark. Doing this cuts the distributor cap and rotor out of the equation. If there's still no spark it could be a bad ignition coil. Some places like Autozone will test the coil for you if you bring it in. If it tests good you might want to replace the crank sensor first.
Old 07-13-2021, 01:58 PM
This is going a lot slower than i would like but I checked the resistance of the coil and it read between 2.8 - 2.9 oms, measured across the power input leads
thoughts?
By the way this is actually a 5.2 liter not 5.9
Old 08-21-2021, 10:12 AM
Hi guys, I got my van running it seems like the coil was a big part of the problem, but once again, it will only run when I keep my foot on the pedal and keep the revs up a bit, if i take my foot off it will stall, it does show on the gauge that its charging, any ideas?
Old 08-22-2021, 10:38 AM
The IAC valve is sticking. You can take it off and try to clean it, or you can replace it.
