Old 05-29-2021, 11:36 PM
Amandadevon1987 Amandadevon1987 is offline
Exclamation 02 grand am 3.4 brakes, dash lights, noise, you name it
Weve changed the brakes, outer tie rods, rack and pinion and wheel bearings but my check engine light, abs, and traction light wont go off plus still having problem with The drivers side makes a loud growling noise when using the brakes and sometimes you dont even have to be using them. When I hit my brakes hard or if I ease on them the driver side catches first. And then sometimes my steering wheel just goes like crazy and jerks side to side. Its guzzling twice as much gas in the past month. Sometimes it acts like something holding it back when trying to go forward. Sometimes it acts as if it dont want to shift gears. And sometimes it idles high and I cant get it to stop. We switched the motor in it and now the horn doesnt work. When at speeds of 60 or more the vibration is horrible. It pulls to the right bad. Gosh I know there is more then that but I'll have to add them on later. I'll also post a list of everything we have already changed on it.
Old 05-29-2021, 11:46 PM
Exclamation Re: 02 grand am 3.4 brakes, dash lights, noise, you name it
Oh and another problem it starts getting hot just out of the blue it only does it every now and then.
Things we have put on it brand new
Led headlights
Reservoir
Outer tie rods
Wheel bearings
Brakes (twice)
Tires about a year ago
Rack and pinion
Fuel injection pressure regulator
So what else does it need.
