Go Back   Automotive Forums Car Chat > Nissan > Titan
Old 05-26-2021, 07:19 PM
eric58 eric58 is offline
Trailer lights
Greetings all, I have a 2009 Titan, I routinely pull a utility trailer with it. The lights on the trailer stopped working. I replaced the wiring and the lights on the trailer, still not working. I checked 2 fuses in the truck, one was a ten amp labeled trailer tow (located in the larger fuse box) and the other was a 15amp fuse labeled TTow turn (located in the smaller fuse box just forward of the larger fuse box). Both fuses are good but still no lights. I will hook the trailer to a friends truck to check and see if the lights work, but I don’t think that’s it. Does anyone know anything else I should check or have any ideas. Thank you, Eric
Old 05-27-2021, 06:16 AM
aleekat aleekat is offline
Re: Trailer lights
I'd first check if you have voltage at the harness plug. Then I'd verify good ground.
Post back, that's what makes Forums Work.
Old 05-27-2021, 08:11 AM
Re: Trailer lights
Thanks, a couple of other people I talked to said to check the ground as well. I appreciate you taking the time to reply.
Old 05-27-2021, 03:55 PM
Re: Trailer lights
It was the ground, there was not enough bare metal, a little sandpaper and some elbow grease…..Lights!
