Go Back   Automotive Forums Car Chat > Cars in General
Old 05-25-2021, 06:25 AM
Kolusion Kolusion is offline
Question Battery charge light will not turn off
I am having really big trouble with my 1991 Honda Prelude and it's getting to the point where I am starting to feel like I want to get it towed to the wreckers. I don't really want to do that but it's really taking the cake.
I hosed down my engine bay and the battery warning light came on and then an hour later my battery went flat. So far, this is what I have done to try and fix the problem:
- Checked the alternator fuses
- Fully charged the battery
- Replaced the alternator with a remanufactured unit
- Replaced the crankshaft pulley
- Replaced the drive belt
Today I checked the replacement alternators' B terminal with a multimeter and it's reporting just 3.84 volts! I thought perhaps the belt was slipping so I tightened it but it made no difference.
The only thing that I haven't checked is the air conditioner compressor pulley.
This could be a hint but it could also mean nothing... when I first installed the replacement alternator, the battery charge light no longer came on but the drive belt was squealing really loud. Then half an hour later, the squealing stopped and the battery charge light came back on again and has been on ever since.
What do others think?
Old 05-25-2021, 08:07 AM
aleekat aleekat is offline
Re: Battery charge light will not turn off
I've gotten reman alternators bad out of the box.
Post back, that's what makes Forums Work.
Old 05-26-2021, 04:51 AM
Today I used a multimeter to perform tests on the alternator. I hope someone can tell me why the alternator is putting out 3.88 volts only.
All tests were carried out with the engine running at 800 RPM except for the last rectifier test, and the battery cable was disconnected from B terminal.
B terminal with alternator connector connected:
3.88 volts between B terminal and engine
3.89 volts between B terminal and battery negative post
-7.9 volts between B terminal and battery positive post
6.8 millivolts between alternator housing and battery negative post
B terminal with alternator connector disconnected:
0.93 volts between B terminal and engine
0.94 volts between B terminal and battery negative post
-9.74 volts between B terminal and battery positive post
0.64 millivolts between alternator housing and battery negative post
Alternator terminals (grounded to engine/grounded to battery negative post):
IG: Nil/6.2 volts
S: 3 volts/3 volts
L: Nil/6.4 volts
FR: Nil/6 volts
Alternator connector (grounded to engine/grounded to battery negative post):
IG: 11.5/11.52 volts
S: 4.58 volts/4.58 volts
L: 11.49/11.5 volts
FR: 11.81/11.82 volts
Alternator rectifier test with engine running:
Multimeter positive probe to B terminal/Multimeter negative probe to alternator housing: Nil
Multimeter negative probe to B terminal/Multimeter positive probe to alternator housing: -240 millivolts
Alternator rectifier test without engine running:
Multimeter negative probe to B terminal/Multimeter positive probe to alternator housing: -933 millivolts
Old 05-26-2021, 06:43 AM
Is it just me or do others also see a grounding issue with either the alternator or the engine?
Old 05-26-2021, 07:39 AM
Further down in this article are more tips.
https://www.aa1car.com/library/charging_checks.htm
Old 05-27-2021, 01:40 AM
I just tested the voltage between the following:
Battery positive terminal and battery negative terminal
Battery positive terminal and engine
Battery positive terminal and alternator
All results matched, so the problem can't be bad grounding.
Does anyone know what else could be the problem?
Old 05-27-2021, 05:49 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
It sounds like your reman alternator is crap.
Old 05-27-2021, 06:08 AM
Ow. What makes you say that?
Old 05-27-2021, 07:22 AM
I agree with Stealthee. The fact it worked when you first put it in, and now it doesn't. So what voltage do you get directly at the battery when engine is running?
Old 05-27-2021, 07:38 AM
Hmmm yeah, it working at the start and it not working now is strange. But there is another strange thing to this, when it was working the belt was squealing badly, then when it stopped working the belt stopped squealing.
I haven't recorded the figure of what I get at the battery but I do know that the battery goes from 12 volts to 11 volts once I start the car.
Old 05-27-2021, 07:50 AM
Running you should be getting about 13.8-14.3 at idle. It sounds like the alternator seized for a little bit then crapped out.
Old 05-27-2021, 08:03 AM
Yes. Maybe.
Do you see anything abnormal in the test results?
Old 05-27-2021, 08:27 AM
Yes. Maybe.
Check the battery voltage when running. Otherwise you'll just be guessing.
Old 05-27-2021, 08:36 AM
So you don't see anything abnormal?
Old 05-27-2021, 09:55 AM
I think I may have found a clue. S should be 12 volts, have a look at S in the charging system circuit diagram.
http://media.honda.co.uk/car/owner/m...f100/16-66.pdf
Now have a look at my test results of the alternator connector.
IG: 11.5 volts/11.52 volts
L: 11.49 volts/11.5 volts
FR: 11.81 volts/11.82 volts
S isn't even hitting 6 volts, so there is resistance either in the wiring or the fuse. Does anyone know if this is of significance?
