Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 05-24-2021, 12:24 PM
martyhouk martyhouk is offline
Electrical troubleshooting
Recently got a 2011 Sierra. The cruise control and the steering wheel radio controls don't work, so I suspect a problem that affects both. Fuses are all OK. Any advice on where to start looking? Thanks...
Old 05-24-2021, 06:26 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Electrical troubleshooting
Could be a clock spring issue. Is the airbag light on?
Old 05-27-2021, 07:09 AM
No, airbag light initializes normally at startup, then goes out...
Old 05-27-2021, 09:03 AM
ctesla's Avatar
ctesla ctesla is offline
marty, even though airbag light not on, Stealthee might still be partially right;
since you mention you recently got the rig, does it have decal for the 07-14 GM
airbag recall? if so, previous owner could have taken care of that and tech when
they swapped takata, they disconnected steering lead wire for vol/etc, and said
oh well, i flagged hour for one airbag pull and it works..
might look into it; or might just be fuse..
i believe '11 GMC has inside fuse box under dash/behind steering wheel
(cover is removed by screwdriver, can't remember regular or jeweler's size)
cover has code numbers that correspond to radio controls, cruise, etc.
hope this helps..
Old 05-27-2021, 09:07 AM
I don't find evidence the airbag was replaced, but on the NHTSA site it does not show as an outstanding recall. So I'm guessing it's been replaced. And I also suspect something was left unplugged at that time. So there's my project for next weekend...
Tags
control , controls , cruise , radio
