Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 04-30-2021, 07:13 AM
Stevenraytmln Stevenraytmln is offline
MKZ Cylinder 5 misfire
Rod .I need help 2007 lincoln mkz..3.5 cylinder 5 misfire changed plugs ,coils fuel injector Two 02 sensors .The hose to pcv is good
Old 05-02-2021, 07:42 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: MKZ Cylinder 5 misfire
Welcome to the forum! Since presumably your misfire is not giving you a P017x code I moved your post to a new thread. I'm also presuming you were, and still are, getting a P0305 misfire code. Please confirm. Are you getting any other diagnostic codes?
Have you performed a compression check on cylinder #5? Or better yet, a cylinder leakdown test?
-Rod
