Old 05-01-2021, 12:11 AM
Dare_Devil_250 Dare_Devil_250 is offline
Unhappy 1995 k1500 v6 turns over but won’t crank
I have a 1995 v6 4x4 step side that will turn over but won’t start I put a new battery new spark plugs now distributor cap new rotor and new ignition coil but still won’t crank it’s getting gas and the wires on the ignition coil are getting hot when I turn it over please help
Old 05-01-2021, 04:19 AM
Schurkey Schurkey is offline
Re: 1995 k1500 v6 turns over but won’t crank
Do you have spark to the spark plugs?
Are the new spark plugs fouled?
Does the throttle body spray gasoline when someone turns the key to "crank"?
What is the cranking compression of all six cylinders?
How "hot" are the wires to the coil getting?
For the record, "turning over" and "cranking" are the SAME THING. Does this engine NOT CRANK, or does it CRANK BUT NOT START?
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 05-01-2021, 12:04 PM
Blue Bowtie's Avatar
Registered Offender
How did you determine that it is "getting gas?"
There is a remote possibility that the fuel system is a CPFI with remote (poppet) injectors instead of a TBI. If the throttle body has two bores, it is a TBI with a pair of large injector pods centered in the throttle bores. If the TB has one large bore and no apparent inectors mounted above it, it would be a CPFI setup. Diagnosis for each would take a slightly different path.
