Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 04-16-2021, 07:40 PM
Andrizzi_d Andrizzi_d is offline
Is it electrical?
2007 sonata would start dying and not start like the battery was dead as if the alternator needed to be replaced so I did replace the alternator and the belt and it's still drains the battery something is draining the battery power it won't shift when I do have a battery in its full it does strange things like that if I have a full battery it will just drain within 2 starts
Old 04-17-2021, 07:48 AM
aleekat aleekat is offline
Re: Is it electrical?
How old is your battery? Have a load test done on your battery. Most autoparts stores do it for free.
Post back, that's what makes Forums Work.
Old 04-17-2021, 08:47 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
A battery with a dead cell will show full voltage, but not act like it has full voltage. I had a battery that needed jumped to start the car, the car would drive excellent with no electrical issues no matter where I needed to go, but as soon as I shut the car off the battery needed jumped again.
Old 04-17-2021, 12:46 PM
I already checked that to and the car literally dies while driving. When I pull over and try to put it in park I can't unless I have power going to the battery or put my key in the slot near the shifter so I can .
Old 04-17-2021, 05:31 PM
Stealthee's Avatar
It still sounds like your alternator isn't charging. You have to do some proper diagnosis instead of throwing things at the wall and seeing if they stick.
