Old 04-07-2021, 01:30 PM
ASJT3 ASJT3 is offline
Send a message via AIM to ASJT3
Pitman Arm - Can I avoid breaking P/S line joints?
'93 K1500. Huge slop in the pitman arm causing hilarious amounts of vibration after going over bumps and probably also prematurely wearing my tires.
My question is, to install the new pitman arm I'd like to avoid the mess of undoing the power steering lines from the steering gearbox. Can I detach the gearbox/pitman from the centerlink, frame, and steering wheel extension shaft and then slide the gearbox over to where I can get at the hold-down nut with my impact from underneath? Again, the motivation is to avoid spilling P/S fluid. Replacing the arm on my old C1500 was a lot easier without the frame cross-member that obstructs access in the 4x4 trucks....
Thanks!
2008 Tahoe SSV, 2007 Tahoe SSV, 94 GMC K1500, 93 Chev K1500, 91 GMC K1500, 2000 Wrangler Sport
Old 04-07-2021, 01:40 PM
maxwedge maxwedge is offline
A990 racer
Re: Pitman Arm - Can I avoid breaking P/S line joints?
That should work, but you may need some heat and use a really good Pitman removal puller.
Old 04-07-2021, 07:38 PM
ctesla's Avatar
ctesla ctesla is offline
--sorry for the delay; in covid line most of day--
max is right; if you are doing it with hand tools, the torch is your friend, along with; like he mentioned, a good pitman puller (not a cheapie that'll bend as soon as you start cranking), and a nice 5pound boilermaker hammer, and even a pickle fork sometimes as a soft wedge/pry instead of sharp edge pry that could bugger threads..
but if i am flagging hours, to speed process, take an air grinder, and put a decent notch in the outer edge, furthest away from steering gear threads, and then follow with the air chisel (it's not like your saving the old one for next time); and that vibration and split will usually pop it right off..
..and, if you've got a day, throw any of your steering/suspension components and rubber bushings and grommets in the freezer overnight.. yea, yea; laugh, but that small amount of condensation on metal is natural WD, and all your rubber (neoprene not so much) will contract and give you that extra 2mm to start threading, as they warm and start expanding..
PLUS- if you did have to move your p/s lines (dang GM and their undercarriage placements), use a heavy duty hemostat (just like a surgeon) on pump side, and a 1/2"vacuum plug on gear box side.. then at least it is only a silver dollar puddle, not lake superior..
Old 04-08-2021, 10:05 AM
Schurkey Schurkey is offline
Drop the hoses, use a big drainpan, take advantage of the situation to change/flush PS fluid.
Not a horrible idea to verify condition of the frame rail and steering gear bolts, either. Rust at the framerail is not unheard of.
An air hammer and chisel on the Pitman arm is not doing the bushings/bearings on the Pitman shaft any favors.
Consider replacing the Pitman shaft seal while you're in there.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 04-08-2021, 10:19 AM
ctesla's Avatar
trust me.. i've been driving these us roads for longer than i've spun a wrench; and 5 seconds of 150psi is nothing compared to what american roadway infrastructure is doing to the pitman shaft..
https://www.youtube.com/watch?v=lXtwj0dhmLU
-- 'sweet project cars' even films it..
