Go Back   Automotive Forums Car Chat > Citroen > Xsara | Xsara Picasso
Old 03-09-2021, 10:16 AM
Fincham Fincham is offline
Xsara Picasso fuel tank removal
Hi .. I need to remove the fuel tank from the car to access a faulty pump. I have the tools and height needed to remove it but the problem I have is the almost full tank of diesel.
What would be the best way to drain the fuel out of the tank as there is no drain plug ?
Thanks for all your help
Old 03-09-2021, 06:42 PM
aleekat aleekat is offline
Re: Xsara Picasso fuel tank removal
If the fuel pump is bad, then siphoning is an option.
Post back, that's what makes Forums Work.
Old 03-09-2021, 06:48 PM
ctesla's Avatar
ctesla ctesla is offline
or you could use a chunk of fuel hose, some speaker wire to the car's battery, and the new fuel pump; IF you can get the top of the tank opened without first dropping, AND you can drop the new pump in..
