Go Back   Automotive Forums Car Chat > SEAT > Toledo/Leon
Old 03-02-2021, 01:30 PM
Diver Izrod Diver Izrod is offline
Seat Leon 1.9 TDI 2008 clutch or gear box problem?
Hi. I'il describe the problem briefly. When the engine is turned off, the gear change without a problem. However, when I start the engine and switch to the first gear, the clutch pedal fails and the gear lever locks. After I turn off the engine and manually lift the clutch pedal, again everything is fine.
Is this a gearbox problem or a clutch problem?
Thank you very much
